These engines have a compression release. With it working, 90 to 100 pounds of compression is the maximum you'll measure. While you have the head off, clean any carbon buildup from the head and piston. a compression tester doesn't tell you much on these engines. A far more accurate way to determine the trouble with your engine is with a cylinder leakdown tester. You can buy one from Harbor Freight for less than $50 that works great on these little engines. If you don't have one, you'll need a small air compressor as well. But that will come in handy for a lot of other tasks, so is a good investment. It'll tell you if the valves are sealing properly, or leaking, and which one. Also, will tell you if the rings are badly worn. Basically, it pressurizes the engine with compressed air, the guages tell you how much air pressure is going in the cylinder, and how much is leaking out ( won't hold the pressure going in). By listening, and feeling around the carb, muffler, and dipstick, you can find the source of where the air is leaking out. no engine is 100% air tight though. Even a new engine has some air leaking by the rings. You should get very little past the valves though. Also, the Service manual for these engines is available from Kohler's website for free. its about 15MB, so a high speed internet connection is recommended for that. But dial-up will do it, just may take most of the night.
