682 Cub Cadet
Dustin Leistra
07-25-2007 18:35:22
yes just wondering the year of my newly aquired cub cadet 682 and if they made a snow blade for it has manual lift dont think i can make my blade off of my 1650 fit? serial # is 2050593U690783 guy i bought it from sayz it would speed up on its on anyone ever had this problem?
R Bedell
07-26-2007 03:28:29
 Re: 682 Cub Cadet in reply to Dustin Leistra, 07-25-2007 18:35:22
You Cub 682 was made in March of 1981.
Yes on the front blade. There was a 42" or 54" model available. The one from your 1650 should mount right up also.
Speed up....??? You will have to be more specific..!!
Dustin Leistra
07-26-2007 16:09:16
 Re: 682 Cub Cadet in reply to R Bedell, 07-26-2007 03:28:29
duno really hasent messed up on me yet he just said while he was cutting grass with it it would take off at full speed across the yard and the hydro control lever would only be about half speed so duno he claimed he put all new valves in the rear? and still didnt fix the problem any info is appreciated Thank you for your reply Dustin Leistra
R Bedell
07-26-2007 16:42:45
 Re: 682 Cub Cadet in reply to Dustin Leistra, 07-26-2007 16:09:16
What I meant....are you talking about an Engine Speed up problem or a "ground" speed up problem..??
Dustin Leistra
07-26-2007 17:32:42
 Re: 682 Cub Cadet in reply to R Bedell, 07-26-2007 16:42:45
ground
R Bedell
07-27-2007 03:10:23
 Re: 682 Cub Cadet in reply to Dustin Leistra, 07-26-2007 17:32:42
Usually the problem with ground travel speed up is due to the tension on the Hydro lever is inadequate.
The friction disk needs to be adjusted to proper tension.
Dustin Leistra
07-27-2007 18:00:59
 Re: 682 Cub Cadet in reply to R Bedell, 07-27-2007 03:10:23
about the blade is there a different bracket i can make to make a 1650 work because the 1650 has a hyd lift and the 682 is manual know were i can geta 1650 blade really cheap so was just wondering looks like a totaly diff hookup on the lift part anyways as always info is greatly appreciated Thank You Dustin Leistra
R Bedell
07-29-2007 14:44:02
 Re: 682 Cub Cadet in reply to Dustin Leistra, 07-27-2007 18:00:59
third party image
Both the 682 and 1650 are wide frame Cubs. Attachments should easily transfer from one to another.
The only difference maybe the "lift rod". If that is the case. You can make your own. Simply drive the Cub up and onto some 2 x 4 or 6 or 8" lumber. Leave the blade down. Put the lift lever all the way forward. Measure the distance between point A & B.
Lift rods can be made of several types of steel stock. Rod, tubing, and flat stock.
Dustin Leistra
10-06-2007 16:12:07
 Re: 682 Cub Cadet in reply to R Bedell, 07-29-2007 14:44:02
yes just wondering how i would go about adjusting the friction disk an were that is located because this darn things just bout goten away from me now 3 times after ive goten off of it any info is greatly appreciated also know a good place to get rid of some parts for a 169 cub thanks again Dustin Leistra
