BS 18 HP Vert. Shaft
WalterBS
07-26-2007 06:47:21
carb stopped up from bad gas so I had a friend put the carb. in carb cleaner he uses for boat engines. This stuff is called chem cleaner. Now I have a problem with the motor running too rich. The float value is properly set according to engine book and new needle valve (rubber tiped) on float. The idle mixture needle valve does not have any effect on the engine. Do you think this carb cleaner was too strong and eat up some internal passages in carb?
CENTAUR
07-26-2007 09:56:22
 Re: BS 18 HP Vert. Shaft in reply to WalterBS, 07-26-2007 06:47:21
Carb-cleaners will not attack metal but will attack some non-metalic parts RIGHT NOW.It is important to rinse and BLOW OUT INSTANTLY so nothing gets a chance to clog what you have just disolved.USE HIGH VOLUME BLOW GUN. CENTAUR
