BS 18HP V. shaft running rich
walterBS
07-26-2007 18:13:56
I have a shop manuel but no trouble shooting guide. What can cause a run rich problem? Float set wrong, worn needle valve? I talked to the local B&S shop, they said the carb was worn out, but I don't buy that answer. Any other suggestions?
El Toro
07-26-2007 18:43:25
 Re: BS 18HP V. shaft running rich in reply to walterBS, 07-26-2007 18:13:56
If that carburetor has a main jet adjusting screw near the bottom of the carburetor, it may need to be closed some. This will lean the fuel mixture. Hal
walterBS
07-26-2007 19:46:45
 Re: BS 18HP V. shaft running rich in reply to El Toro, 07-26-2007 18:43:25
the needle valve with spring can be screwed in all the way and does not affect the rich running.
vitzarus
07-26-2007 22:35:41
 Re: BS 18HP V. shaft running rich in reply to walterBS, 07-26-2007 19:46:45
Sounds like the old float/needle cutoff situation. With old gas,time,additives etc they stick open or closed. Jetting yes also. Say for instance somebody had an intake leak and it seemed non-correctable. Another larger orifice jet was introduced which balanced the mixture at higher speed. If you or wear corrected the origional problem then the oversized is incorrect and can run rich.
