B S 11 hp
hnp4134
08-08-2007 19:03:45
I pulled the crankcase cover off and there are two gear driven counter weights that are mounted to the cover. I assume they need to be "timed" with the crank when installing the cover. How do you do this? This is a mid 80's horizontal engine.
JT
08-09-2007 06:08:52
 Re: B S 11 hp in reply to hnp4134, 08-08-2007 19:03:45
These are your balance gears, to time them when you put it together. There should be two bolts in the cover, take them out then take two small peices of wire, put in the holes, turn the gears untill the rods lock into a hole in the gear. Then you can put the engine back together, that will time it.
hnp4134
08-09-2007 18:01:52
 Re: B S 11 hp in reply to JT, 08-09-2007 06:08:52
What position does the crank need to be in when putting back together?
JT
08-10-2007 06:59:35
 Re: B S 11 hp in reply to hnp4134, 08-09-2007 18:01:52
Will have to look and see how it is done, been a long time since I ahve put one togehter
