Bolens 1050 battery drain
Mike
09-23-1999 12:55:24
My battery in my Bolens 1050 tractor goes dead in just a couple of days. The battery is new and I checked the wiring for shorts.The ignition switch tests good. The Amp gage shows charging when tractor is started. Could it still be the voltage regulator? Any ideas are welcome.
Stan
09-24-1999 10:40:51
 Re: Bolens 1050 battery drain in reply to Mike, 09-23-1999 12:55:24
Perhaps. There is a nice 1050 wiring schematic in the photo section of the Bolens club on Yahoo.
Link
You probably have already tried this, but disconnect the negative cable on your battery and use a 12volt test light or electronic tester between the post and the cable to see if there is a draw. Trace backwards from there.
paul
01-02-2000 13:13:29
 Re: Re: Bolens 1050 battery drain in reply to Stan, 09-24-1999 10:40:51
try checking out www.angelfire.com he has electrical schematics on his web page
