1200 Cub Cadet Charging Problem??
Jim in Ohio
08-12-2007 16:54:57
I have a charging problem with my 1200 Cub Cadet. I can charge the battery and mow for a couple of hours. I mistakenly thought I was low on gas. Cruised over to the garage, filled it up, dead battery. I did the recommended checks. Across each stator pole to ground when running I get about 30 volts AC. Plug in the connector, all I get for output is what the battery charge is at that time. (12.75 with the key on with the tractor not running, 12.25 with it running) I guess I can assume the regulator/rectifier is dead? It is mounted on the metal flywheel housing. Where can I buy this part?? Thanks for any help, Jim
tedsxb
08-22-2007 18:08:44
 Re: 1200 Cub Cadet Charging Problem?? in reply to Jim in Ohio, 08-12-2007 16:54:57
Ive had this happen to me on a 1650 and i replaced the voltage regulator. Now, when i fire her up, the amp gauge on the dash pegs to C and even with my lights and deck on never goes below 0.
R Bedell
08-12-2007 18:57:52
The B+ Terminal should have a Max of 14.7 VDC at 3600 RPM's. The V/R "has" to be properly grounded for it to work correctly.
You should check to see if you have zero ohms resistance between the V/R Case and the Battery (-) terminal before replacing.
See link for additional information
joe csuti
08-12-2007 17:51:45
Take eng make,mod#,type or spec# to local mower shop & have them order for you,or try several of the online dealers with parts lookup & get part# for reg & order from them.
Jim in ohio
08-15-2007 05:15:53
 Re: 1200 Cub Cadet Charging Problem?? in reply to joe csuti, 08-12-2007 17:51:45
Did some more checking. .3 ohms resistance across the two stator coil wires. Across the two stator wires, at WOT, I get 35 volts AC. Plug in the grounded regulator/rectifier, and output doesn"t change. All I read is the battery voltage. (this time about 12 volts DC.) Should I replace the stator coil as well?
