Assembly diagram for CC stick shift drrive shaft
Greenfrog
08-21-2007 16:21:46
ATT: Mr. Bedell and others. Thanks in advance. I need a diagram for the assembly of the driveshaft for a CC 108...in order to get everything in the right order.....the thrust bearning, spring, etc. (one time I had the dealer do this and they put the thrust bearing on backwards!) Keeps the patrons coming back!
oldrustycars
08-22-2007 15:55:14
 Re: Assembly diagram for CC stick shift drrive shaft in reply to Greenfrog, 08-21-2007 16:21:46
4 is a tickler spring, it helps keep the clutch disengaged when you step on the peddle. Mine didnt have one, used it for years, rebuilt it 3 times, never had a diagram and since there wasnt one I didnt know it was missing. Made a huge difference when I assembled the shaft correctly...its been 5 years since it was out of the machine.
Wrench Spinner
08-21-2007 19:41:49
third party image
Good Luck.....
Greenfrog
08-21-2007 20:49:33
 Re: Assembly diagram for CC stick shift drrive shaft in reply to Wrench Spinner, 08-21-2007 19:41:49
Thanks. That is perfect. There seems to be a little confusion on parts 4 and 20. I dont see a spring when I look in there. Huh? I may have to take the shaft out. It appears to be noisy, however I just replace parts last fall.
