8 hp BS carb. problem
Tony Cusimano
08-23-2007 14:27:25
Hi,
Just picked up an old Toro Wheel Horse with an 8 hp Briggs and Stratton engine.
Model: 195707
Type: 0121
Code: 93011410
Hadn't been run in 10 years, put in a new battery and it fired right up but then died after about a minute. Engine turns over fine still but won't start. Gas leaking from the carb. onto the frame. Any suggestions for a rebuild kit or totally new carb. If this sounds like the problem advice would be greatly appreciated. Also where to buy such items if readily available.
I've seen lots of rebuild kits online but don't know what type of engine this is...horizontal, vertical etc. Thanks
Joe Fred Fournet
09-06-2007 04:39:05
 Re: 8 hp BS carb. problem in reply to Tony Cusimano, 08-23-2007 14:27:25
Looking for Tony C, who went to USL in 1981 and 1982. Thanks.
phil(va)
08-25-2007 20:03:53
You didn"t say if you flushed the gas tank and put in new gas? If you did not, that could very well be the problem or at least a big part of the problem.
Tim in NB
08-23-2007 17:27:26
The carb kit for this engine is Briggs & Stratton #497535. It will cost around $40.00. I get most of my briggs parts from Jacks small engines in MD via UPS, but any small engine shop should be able to get you the carb kit.
Tony Cusimano
08-24-2007 04:08:57
 Re: 8 hp BS carb. problem in reply to Tim in NB, 08-23-2007 17:27:26
Thanks. What part of MD, I"m in Frederick?
Tim in NB
08-24-2007 16:07:13
 Re: 8 hp BS carb. problem in reply to Tony Cusimano, 08-24-2007 04:08:57
Jacks is in Jarrettsville. 1-877-737-2787 or jackssmallengines.com.
I live in New Brunswick, Canada.
Tony Cusimano
08-26-2007 08:26:45
 Re: 8 hp BS carb. problem in reply to Tim in NB, 08-24-2007 16:07:13
Thanks for the help, placed my order on Friday...cross my fingers.
RN
08-23-2007 14:58:47
19 cubic inch. probably 'Horizontal' crankshaft with Cylinder upright. If cylinder is laying down with the flywheel on top the crankshaft is 'vertical'. Carb float and needle/seat assembly known to dryout/corrode when setting a long time, main jet and needle foul also from setting- clean with fine wire and carb cleaner. RN
Tony Cusimano
08-24-2007 04:24:41
 Re: 8 hp BS carb. problem in reply to RN, 08-23-2007 14:58:47
Thanks for the reply, I'll give it a try, I'd love to get it working.
vitzarus
08-24-2007 21:56:56
 Re: 8 hp BS carb. problem in reply to Tony Cusimano, 08-24-2007 04:24:41
It's probably going to be fine if you don't screw up the linkage.By fact that it ran makes the main jets open. By fact it stuck and gas was leaking indicates only which was described that the float and needle have reacted to old fuel and got sticky. It goes without saying perhaps but well yes it goes without saying.
T.R.K.
08-26-2007 12:13:59
 Re: 8 hp BS carb. problem in reply to vitzarus, 08-24-2007 21:56:56
When you take it apart, give the float a shake. It may have gas in it and it will slosh when you shake it.
