Case 444 start / run problesm
Jim Oatey
09-26-1999 17:44:32
I have a Case 1979 444 with a 14 HP Koeler engine. Last winter it would start, and run but smoke bad and loose power. I Rebuilt the carb but that did not seem to help.I just adjusted the Valves and the exhaust was in need of loosening. Now my problem seems to be electrical, I cannot get enough power to make it roll over. The battery has plenty of power> Does any one have any ideas on these 2 problems.
Mike H(MD)
09-27-1999 17:31:51
 Re: Case 444 start / run problesm in reply to Jim Oatey, 09-26-1999 17:44:32
Jim
It sounds like it may be time for a complete overhaul on you engine as the ring may be worn.Get a manual for your model engine and d a compressin check to be sure.
For your second problem I recommend getting yourself a volt meter and start by checking your battery with your starter engaged. If the voltage drops below 10 volts I recommend trying another battery as you may have a bad cell in it . Hope this helps..Mike
