CuB Cadet no start!
Gary_602z
08-27-2007 16:21:57
Hello All!
I have a Cub Cadet LT1050 (23 horse Kohler) bought new this year. All of a sudden it won't start. I don't seem to be getting any spark to the plugs. Anything to look for or any common problems? About once a day it will fire and then immediatly quit. After that it won't fire,spit or sputter.
Any manuals or check procedures that I should go thru?
Thanks in Advance!
Gary
JT
08-29-2007 06:39:52
 Re: CuB Cadet no start! in reply to Gary_602z, 08-27-2007 16:21:57
Gary,
Are you checking for fire at the plugs with a tester or just saying it has not fire because it will not start. If it does not have fire to both plugs, it is not the coils, t it has two coils on it, and they are independent of each other, so if ti has no fire to the plugs on both cylinders, then you could have a multitude of things wrong with it.
Gary_602z
08-29-2007 19:36:12
 Re: CuB Cadet no start! in reply to JT, 08-29-2007 06:39:52
Thanks all! I got it going by polishing the magnet on the flywheel. I don't know if it was interfering with the coils but it was a little rusty.
Thanks
Gary
Here is something that me and my buddy built last winter. It is either a Lawn Splitter or a Wood Mower!
pbase.com/gary_602z/image/75564801/medium.jpg
Just copy and paste with the www in front as the site won't let me post a pic!
Wrench Spinner
08-27-2007 16:50:23
If you just bought it new this year take it back to your dealer and let them deal with it !
If you bought it from a chain store contact them for the nearest Cub warranty repair station.
Gary_602z
08-27-2007 17:03:49
 Re: CuB Cadet no start! in reply to Wrench Spinner, 08-27-2007 16:50:23
Yea I was just hoping I wouldn't have to drag it in to get serviced! I would almost rather buy the part if it isn't to badly priced.
Gary
El Toro
08-28-2007 04:06:43
 Re: CuB Cadet no start! in reply to Gary_602z, 08-27-2007 17:03:49
Your owner's manual should tell you where to get service. My nephew has the IH dealer to pick up his Cadet. I would give them a call. If it was made by MTD they may have a service center. I wouldn't tear into since its under warranty. It may void your warranty. Hal
El Toro
08-27-2007 16:48:56
The electronic module or coil is probably weak when it gets warm. That should be covered under your warranty. Hal
