Wrench Spinner
08-28-2007 18:42:55
Re: 12Hp Briggs Help Needed in reply to Wrench Spinner, 08-28-2007 18:37:32
Ref # Part # Description 1 490450 Add to pick list Cylinder Assy. 1 2 399265 Add to pick list Bushing/Seal Kit 1 3 391086 Add to pick list Seal-Oil 1 7 271866 Add to pick list Gasket-Cylinder Head Included in Gasket Set-Part No. 490525 1 8 391406 Add to pick list Breather Assy. 1 9 27803 Add to pick list Gasket-Valve Cover Included in Gasket Set-Part No. 490525 1 10 94621 Add to pick list Screw 1 11 280100 Add to pick list Tube-Breather 1 12 271916 Add to pick list Gasket, Crankcase (.015") Included in Gasket Set-Part No. 490525 1 12 271996 Add to pick list Gasket, Crankcase (.009" Thick) Included in Gasket Set-Part No. 490525 1 12 271997 Add to pick list Gasket, Crankcase (.005" Thick) Included in Gasket Set-Part No. 490525 1 13 93723 Add to pick list Screw, Machine Hex (3" Long) 1 15 91084 Add to pick list Plug, Pipe (Standar (3/8") 1 16 490466 Add to pick list Crankshaft Order Part No. 94196 For Timing Gear Key. 1 18 490452 Add to pick list Base-Engine 1 20 291675 Add to pick list Seal, Oil (Used In Crankcase Covers) 1 21 66768 Add to pick list Plug, Oil Fill 1 22 94305 Add to pick list Screw-Base Mtg. Sem 1 23A 490428 Add to pick list Flywheel-Magneto Used Before Code Date 88090600 1 23A 492135 Add to pick list Flywheel Assy (For Rewind Starter Engines) 1 24 222698 Add to pick list Key, Flywheel 1 25 394661 Add to pick list Piston/Ring Kit (Std.) 1 25 394662 Add to pick list Piston/Ring Kit (.010" O.S.) 1 25 394663 Add to pick list Piston/Ring Kit (.020" O.S.) 1 25 394664 Add to pick list Piston/Ring Kit (.030" O.S.) 1 26 394665 Add to pick list Ring, Piston Kit (Std.) 1 27 260924 Add to pick list Lock-Piston Pin 1 28 299691 Add to pick list Pin-Piston Std (Std.) 1 10 28 391286 Add to pick list Pin-Piston 005 (.005 O.S.) 1 10 29 490348 Add to pick list Rod-Connecting (Standard) For Connecting Rod With .020" Undersize Crankpin Bore-Order Part No. 490469 1 31 222299 Add to pick list Lock-Screw 1 10 32 92909 Add to pick list Screw, Hex Head Cap 1 33 262246 Add to pick list Valve-Exhaust 1 34 262247 Add to pick list Valve-Intake 1 35 65906 Add to pick list Spring, Valve 1 36 26828 Add to pick list Spring, Valve (Exhaust) 1 37 223752 Add to pick list Guard-Flywheel 1 40 221596 Add to pick list Retainer, Spring (Used With Valves With Groove In Stem) 1 41 292260 Add to pick list Rotocoil Assy (Exhaust Valve) 1 42 93630 Add to pick list Keeper, Valve (2) 1 45 262248 Add to pick list Tappet-Valve 1 46 212897 Add to pick list Gear-Cam 1 98A 90200 Add to pick list Screw-Slotted (8-32 X 1/2") 1 10 99 26157 Add to pick list Spring, Compression 1 188 93535 Add to pick list Screw, Sem Hex Head (5/16-18 X 3/4) 1 201 261609 Add to pick list Link-Mechanical Governor Used Before Code Date 87010700 1 201 262348 Add to pick list Link-Mechanical Governor Used After Code Date 87010600 1 209 260695 Add to pick list Spring-Governor Used After Code Date 87010600 1 209 260871 Add to pick list Spring, Governor (For 2700 To 3300 R.p.m.) Used After Code Date 87010600 1 209 260902 Add to pick list Spring-Governor Used After Code Date 87010600 1 10 209 261126 Add to pick list Spring-Governor Used After Code Date 87010600 1 209 261129 Add to pick list Spring, Governor Used Before Code Date 87010700 1 219 391764 Add to pick list Oil Slinger, Gov. Gear Assy. Used Before Code Date 87010700 1 219 490815 Add to pick list Slinger-Oil Used After Code Date 87010600 1 222 491594 Add to pick list Bracket-Control (Choke-A-Matic) 1 5 225 231058 Add to pick list Crank, Governor (1/4" Dia.) 1 227 391733 Add to pick list Governor Control Le (For 1/4" Dia. Crank) Used Before Code Date 87010700 1 227 490927 Add to pick list Governor Control Le (For 1/4" Dia. Crank) Used After Code Date 87010600 1 230 94742 Add to pick list Washer, Plain 1 232 260584 Add to pick list Spring-Link Used After Code Date 87010600 1 232 261911 Add to pick list Spring-Governor Link Used Before Code Date 87010700 1 10 265 221535 Add to pick list Clamp, Casing (Stamped Steel) 1 284 93572 Add to pick list Screw, Hex Head Tap (10-32 X 3/8) 1 304 490689 Add to pick list Housing-Blower 1 305 93158 Add to pick list Screw, Sem Hex Head (1/4-20 X 5/8") 1 306 224545 Add to pick list Shield-Cylinder 1 307 93163 Add to pick list Screw, Sem Hex Head Used Before Code Date 90051400 1 307 93949 Add to pick list Screw-Sem Used After Code Date 90051300 1
