3pt.hitch
Dude11
09-13-2007 19:02:24
I'm aware of what "o"Cat.and Cat.3's are;what's the difference with Cat.1? I'm looking at an all purpose plow that looks like a o cat.but it just seems a little heavy for 12 thru 18hp.Garden tractor range.Is there a stamp or marking of some kind to look for?I've never seen one like it,has a straight square tube bar,the spring tongs are adjustable and slide for adj.There are 5 tongs.Unit is orange,about 36"long and really don't look that old!thanks in advance,Dude11
Bills1450
09-14-2007 19:28:08
 Re: 3pt.hitch in reply to Dude11, 09-13-2007 19:02:24
It sounds like you are describing a cultivator used for weeding / breaking up the ground purposes not really a plow. They are meant for use in already tilled ground which doesn't require as much pulling power.
CENTAUR
09-13-2007 19:20:50
LOOK TO THE LEFT UNDER (RESEACH AND INFO).3POINT SPECS. CENTAUR
Dude11
09-13-2007 19:52:16
 Re: 3pt.hitch in reply to CENTAUR, 09-13-2007 19:20:50
Thanks centaur,Pays to look to the left from time to time,Dude11
les_from_syracuse
09-14-2007 10:28:45
 Re: 3pt.hitch in reply to Dude11, 09-13-2007 19:52:16
I have White GT2055 (MTD 20 hp) with a class 0 3-pt hitch and it handles a 300 lb box blade fine. My father has the same tractor with an 18 hp engine and we've had the box blade on that without a problem. The box blade was originally set up with Class 1 pins and class 0 spacing, but I swapped out the pins and it works fine on the class 0 hitch. My blade is orange also and was made by KingKutter. Maybe you could find your plow on their website?
