Best way to fix crankshaft journal - Briggs
9NJoe
09-25-2007 17:10:18
Had my briggs 13 horse seize up on me due to oil leak. Checked it out and only problem is conn rod to crank journal is galled. I plan on getting a new conn rod but what is the best way to clean up the crank? I could hit it with crocus cloth but is there a way to dissolve the aluminum without harming the steel? Someone told me about soaking a rag in muriatic acid and laying it on the journal for a short time. Any tricks to this?
Joe
chuck in Indiana
09-26-2007 13:23:46
 Re: Best way to fix crankshaft journal - Briggs in reply to 9NJoe, 09-25-2007 17:10:18
soak the crank in bleach over night.This will get the metal off.It will dis color the crank but is ok.Than polish.
Kentb of SWMO
09-26-2007 06:27:59
Tuen crank pin .020 inch undersize and order a under size rod from B&S dealer.
Kent
El Toro
09-25-2007 18:13:44
I would have your auto machine shop to examine that crankshaft. It may need to be ground undersize. I would find out before having it ground if undersize rods are available. I had this done an old B&S 23B. Hal
Tom Arnold
09-25-2007 17:51:00
I just went through this with a 12 hp I/C that snapped a rod apart at the cap.
Took the crank to a crank rebuilder. He stuck it in his tank overnight to remove all the galled aluminum and then polished the journal. Cost me $30.00 to get a crank back from a specialist who assured me that it was now ready to be put back into service without a worry.
Cheap insurance that the engine isn't going to grenade anytime soon
