Backfireing B S 10hp
jward
10-05-2007 09:21:26
I have a 1974 Speedex 1030 that has just started acting up. It seems to be missing and running rough and it also backfires when idling down. Aney Ideas? I have adjusted the main jet to no avail. The spark plug has heavy black soot on it.
Thanks.
JT
10-05-2007 14:21:18
 Re: Backfireing B S 10hp in reply to jward, 10-05-2007 09:21:26
If you have checked all the things everyone else told you to check, did you check the points to make sure you have good fire there? If the points get a little corroded, you will get a week spark and that will cause running rough and backfiring like you are describing.
supergrumpy
10-05-2007 13:26:21
check your air flow, sometimes a new air filter does wonders
new plug gets rid of some problems too
drain the gas and put in known good stuff
check easy stuff first
jward
10-05-2007 13:37:31
 Re: Backfireing B S 10hp in reply to supergrumpy, 10-05-2007 13:26:21
I leaned the carb to 1 turn out from stop and cleaned the plug. Also checked out air cleaner and the cartridge is like new with foam outer wrap. I will try new gas and taking the precleaner off. Thanks.
supergrumpy
10-05-2007 17:12:51
 Re: Backfireing B S 10hp in reply to jward, 10-05-2007 13:37:31
I have had good looking plugs get oil fouled and just never work right afterwards, or I was desperate and pulled old crummy plug out of a junk motor and it ran just fine
you might have electronic ignition so points suggestion might not work
if you try the easy stuff and no joy, then carefully take carb apart and check it out, might have some dirt or water in, in-line gas filter prevents lots of carb problems
rule of thumb on float level, bottom of float s/b parallel to carb base with carb upside down
El Toro
10-05-2007 11:42:48
You may need to lean the carburetor. Hal
jward
10-09-2007 05:48:20
 Re: Backfireing B S 10hp in reply to El Toro, 10-05-2007 11:42:48
Picked up a new NPK B6S and the thing runs like a champ. Thank you all for your help.
El Toro
10-09-2007 06:32:40
 Re: Backfireing B S 10hp in reply to jward, 10-09-2007 05:48:20
Glad you have it fixed. Hal
