129 cub cadet won't start
shari
10-19-2007 16:07:06
I have been trying to start a 129 for several days. Have put on a different coil, condenser and new plug. Cranking it over with the plug out it looks like maybe it doesn"t fire every time. Any help would be great. DN
shari
10-20-2007 14:33:02
 Re: 129 cub cadet won't start in reply to shari, 10-19-2007 16:07:06
I forgot to mention before that I had cleaned and checked the gap on the points also. I am using a coil off of a cub cadet. Thanks for the help. Any other ideas I will sure try them.
skip176
10-19-2007 18:16:52
Like Joe said clean the points and regap at .20. Now you said it WAS fireing. I had a 149 that would not start but when you laid the plug on the head sheild it had spark. I tried a new plug and started right off. I use autolight 214 I think, off the top of my head so dont hold me to it. Now You might want to be sure you have a coil for a mower not a car. After the car coil fire and the eng runs it cuts the voltage back to 6 volts and your cub wont run right. That will burn your points. Also resand the back of the condensor to be sure you have a good ground, and the condensor is hooked on the neg side of the coil.
Let us know how you do or need anything else.
joe csuti
10-19-2007 17:10:30
Check that points are clean and free of oil,grease & dirt and set to proper gap,if points pitted replace & regap.
