12.5 H.P. BS
alg
10-23-2007 21:31:09
I have a 12.5 Briggs.That's about 20 yrs. old.It's on a Simpilcity lawn tractor.It is in need of a rebuild.Is there a rebuild kit available for this engine.?? Al
Boyd in Mn
10-23-2007 21:54:56
 Re: 12.5 H.P. BS in reply to alg, 10-23-2007 21:31:09
If its a vertical shaft engine you most likely be ahead by installing a new engine. Northerntool.com surpluscenter.com are a few. A rebuilt typically lasts not as long as a new one. Crankshaft sizes are almost all the same dimensions. I think there are 2 or 3 vertical shaft mounting patterns and a lot of mowers are built with 2 sets of bolt holes punched through the frame. Another B&S would probably have the same bolt pattern.
