how to check hydro fluid on 1979 ford lgt 165
AeroArkie
11-09-2007 19:02:53
how do you check hydro fluid and fill on lgt 165
billyinnc
11-11-2007 19:19:34
 Re: how to check hydro fluid on 1979 ford lgt 165 in reply to AeroArkie, 11-09-2007 19:02:53
If it is like my 1973 LGT 165, you should have a drain plug in the very bottom, a plug about half way up in the rear and a small breather almost at the top in the rear. The fluid level should be to where it just dribbles out the center hole and if you have to add any, you remove the breather at the top and pour it in until it runs out the center hole. You probably can put it in the center hole as well until it starts running out and not have to take out the breather.
AeroArkie
11-16-2007 19:16:40
 Re: how to check hydro fluid on 1979 ford lgt 165 in reply to billyinnc, 11-11-2007 19:19:34
thanks for the info aeroarkie
