Ariens Tiller with Tecumseh cast iron engine
dhermesc
11-14-2007 11:13:10
Anyone familar with these? Can you still get parts for the Tecumseh HH70 engine?
It is mounted on a Ariens Rocket VII tiller, it "appears" to be very heavy duty and in decent shape - anyone use this type of tiller?
jdemaris
11-15-2007 08:21:44
 Re: Ariens Tiller with Tecumseh cast iron engine in reply to dhermesc, 11-14-2007 11:13:10
You can get most parts and many other engines will fit in its place. We sold Ariens Rockets new. Much better tillers than Troy Built - but I guess Ariens did not market them as well. Ariens also made big, truck-farm sized tillers. Nice thing about the Rocket is you can disengage the tiller drive without disengaging the wheel drive. You can't do that with a Troy Built.
The HH engine has the same footprint as the aluminum engines you often find on snowblowers. But the HH used OEM on the Rocket is cast-iron and also has a hardened exhaust valve and tapered-cone adjustable bearings for mains on the crankshaft. Troy Built used the same engine on several tillers - along with Briggs and Kohler.
The big HD Ariens tillers were Model As, Bs, A-Transamatic, and TA Multimatic made from the 1930s to the 1950s.
Model A used Wisconsin AAH engine
Model B used Wisconsin AHH engine
Model C used Wisconsin AFH engine
Model D used Wisconsin TF two-cylinder engine
TA20 used Wisconsin AEN, 8 horse
TA20A used Wisconsin AEH, 9 horse
TA28 used Wisconsin TF, 2 cylinder 16.5 horse
TA28B used Wisconsin TH, 2 cylinder, 16.5 horse
Gardener used Briggs Model 8 engine, 2.5 horse
Yardster used Briggs Model 6 engine, 2 horse
Junior used Briggs Model 6, 2 horse
Jet series used Briggs or Tecumseh 3 - 5 horse
Rocket - came out 1960 with 5.5 horse Tecumseh
Rocket VI - came out 1964 with 6 horse Tecumseh
The smaller homeowner tillers included the Gardener G2, Yardster, Junior, Jet, Super Jet, Deluxe Jet, Rocket, and Rocket VI.
dhermesc
11-15-2007 11:12:57
 Re: Ariens Tiller with Tecumseh cast iron engine - Picture l in reply to jdemaris, 11-15-2007 08:21:44
There appears to be to "clutch" handles on the guard covering the tiller tines - should shese move "freely" when the engine is not running?Link
Thanks>Link for the feedback.
Kentb of SWMO
11-15-2007 05:51:49
I saw a Ariens tiller at a swap meet that had a Wisconsin vertical twin of the TF, TH, THD family. This was a obvious FACTORY unit. I was so blown away I had a camera and I forgot to take a picture. Does anyone know about this unit or was this just a BAD DREAM.
Kent
El Toro
11-14-2007 13:33:53
I still have a new coil for one of these engines.
Hal
JT
11-14-2007 12:45:05
Yep,contact your local Tecumseh dealer, he can get most all you want.
Jim
