1951 Wheel Horse what is it worth.
Daryl
10-08-1999 19:55:28
The Wheel Horse runs great.The motor sets between the drivers legs.
It has a 6hp Kohler motor,a one bottom plow,cultivators,& a two blade mow board.
Any help would be appreciated.
I do not know what model it is. Please tell me how I can find out or with the info I have given tell me what model it could be.
Thank you for all your help.
William Pearson
10-09-1999 19:09:33
 Re: 1951 Wheel Horse what is it worth. in reply to Daryl , 10-08-1999 19:55:28
Daryl Wheel Horse made the mid engine design from 1955 to 1961 , if can you find out what type front axle the tractor has (cast iron or steel bar stock) , where the throttle controlls are and what type (pull cables or lever(s)) and what the transmission looks like ( a two piece cast iron unit , a cast iron oval shaped with sheet steel side plates or a belt drive with a set of pulleys )I can ID your tractor . Bill in Richmond , Va.
