BOLENS info?
Pat H
10-09-1999 11:41:05
recently bought bolens1250 at farm auction.it came with spiral log splitter,shaft drive. was this really for the bolens or did someone do a nice job of making it look like it will fit.didnt get a manual with it.any info appreciated thx.
Don Smethers
03-18-2004 15:20:04
 Re: BOLENS info? in reply to Pat H, 10-09-1999 11:41:05
I have a Bolens, can't read the tag, but it may be 192-01 or 195-01.
Need to locate supplier for front wheel bearings, or manual with dimensions and part numbers.
Thanks
cindy
04-20-2002 18:12:37
Need parts for my 1600 hydro bolens garden tractor Where can I find parts in the Lansing, MI area?
David A. Sohn
10-12-1999 10:26:29
To Pat H-- from David A. Sohn 10/12/1999 david.a.sohn@juno.com
I can forward some info I found helpful. Read On. I am rebuilding my 1966-year Bolens Model 1050 192-01 Garden Tractor-- and several attachments for it. I hope to have everything together by the first snow.
I hope this helps.
David A. Sohn Saint Louis, Missouri
Troy-Bilt has service many places-- Check out Troy-Bilt website>Link
Click>Link on "Buy Locally", Click on "Dealer Locator". Enter your Zip Code and you have it.
Troy-Bilt bought out Bolens, but support the old name and the new name under parent company "Garden Way". I am told the bigger Troy-Bilt tractor is based on Bolens design. I may have read that the smaller riders are based on other designs. Ask any of the guys below for better information/ advice than I have.
Under the Photographs sections at these sites, you can find Specifications pages with diagrams and helpful information, but you have to obtain membership first. Happens immediately, and is no-cost.
Link
Link
You will see some of these names and phone numbers for parts and supplies at various websites. These guys are experts, and a great source of advice. Keep them for future reference--
Sonny's Farm & Home Supply (Robert Mann, Todd, and others) 219-726-2808 1733 N.200W. Portland, In 47371-7004 sonnys.bolens@hotmail.com
Ray's Mower Shop (Ray and Noah) 610-367-2078 112 Terace Rd Boyertown PA 19512 RMS1050@aol.com
Horizon Equipment Sales (Robert Fenn) 978-433-8888 8 Townsend St. Pepperell, MA 01463-1281 horizon@bicnet.net Wetsite www.bicnet.net~horizon
Dan Wenninger 414-644-5208 Ackerville@nconnect.net
Bruneau's Power Equipment (Bobby Bruneau) 843-889-8377 4305 Hwy 165 Hollywood, SC 29449-- rbruneau@awod.com
You will also need publications for the Tractor-- and for the Mower Deck. I purchased some publication reprints from Bruneaus-- and scanned files from others. If you cannot read the Mower Deck tags, try this information. Some of the Mower Deck Model Numbers for various 1050s-- 1050 "192-01" built in 1966: The green-colored Deck is connected with two points above the deck-- plus two long links and turnbuckles that connect the back of the deck to the transaxle, or "Two Up and Two Back". The TR-10D Wisconsin engine uses a magneto, with coil located behind the flywheel-- and Does Not have a 12 Volt ignition coil. The 42" deck used is probably a model #18457 or variation-- it uses 14.5 inch blades. 38" deck would probably be 18449-- it uses 13.25 inch blades.
1050 "192-02" built in 1967: The Deck is connected by "Two Up and Two Back" and the engine uses a 12 Volt ignition coil on TRA-10D engine. Same decks as above.
1050 "192-02" built 1968 to 1969: The Deck is connected by "Four Up"-- meaning four points connect the deck directly above the deck itself. Extra lift mechanisms were added to the tractor frame to accommodate this method. This eliminated the need for long links to the transaxle. The 42" deck used might be an 18423 or variation-- this deck was designed to receive four lift points directly above the deck. TRA-10D engine is used (12-Volt Ignition, not magneto).
Glenn(WV)
02-12-2002 15:13:54
 Re: Re: anyone have a rototilling buisness with a lawn garden tractor in reply to Mike, 02-11-2002 21:38:53
Mike is right; don't work for free. When word gets out, people will start expecting it and when you try to charge for it, they'll get mad. BTDT!
James Strader
03-10-2000 03:37:14
 Re: Re: BOLENS info? in reply to David A. Sohn, 10-12-1999 10:26:29
I am looking for an operators and parts manual for an ISEKI Tractor, Model Type,TX2140T No. 002333. BOLENS Model # 1502, Diesel G152. I think the year is 1987,88,or 89. If you can help please reply. Thanks, James Strader
Larry A. Simon
04-11-2001 18:43:22
 Re: Re: Re: BOLENS info? in reply to James Strader, 03-10-2000 03:37:14
I hope you can locate the operator & parts manual for your Bolens, G152, & if you do, where are you going to gets parts. I'm looking for parts for my belly mower, i.e., pully shafts & hubs, I broke two of the three. I've had the pully shafts welded to the blade supports. Sure would like to find part dist. My understanding that Bolens is no longer in business & parts are not available. Good Luck! If anybody can help, please advise....Larry...Appling, GA
Pat H
10-13-1999 09:49:10
thanks David for your info,was very helpful.really enjoying the bolens my wife bought, now we each have one,a 1050& a 1250.thanks again
Bob L
06-18-2002 19:14:37
 Re: Re: Re: 317 charging system in reply to john, 06-18-2002 12:36:18
Hey John;
My 317 did the same thing as yours. Drove me nutz for about 3 weeks till I checked and changed the Magnitic PTO clutch. It had a shorted winding, causing a high amp draw. The clutch can cause A LOT of electricial glitches, burn out what seems to be non related wiring, and be a general pain in the ..... .. well you know where. I got mine from Scheffel Equipment in Somerset PA, and paid an outrageous price, but, I had to have it.
Bob L
Shanksville PA
