John Deere 110 / 112 Tractor Elect. Lift Motor Actuator
Jack in Michiga
12-01-2007 12:18:42
I just picked up this to sell. The guy I got it from said it worked fine, however, I would like to check it out myself before it is advertised. Does anyone have a wiring diagram or dianostic check to share? Also if anyone knows someone who is looking for one let me know. Thanks, Jack
Gene Davis (Ga.)
12-01-2007 19:47:21
 Re: John Deere 110 / 112 Tractor Elect. Lift Motor Actuator in reply to Jack in Michigan, 12-01-2007 12:18:42
We have a Toro sprayer at the golf course i work at. It has 12v actuators for lifting the boom arms. They have one wire for forward(cw rotation), another wire for reverse(ccw rotation) and the third wire is for ground or 12v-. Use an ohm meter to identify the ground wire and the other should be fwd or rev to the field coils of the motor. This is how ours work. there are sometimes limit switches to prevent over extending them.
