Cub Cadet engine lurching
akper
12-03-2007 15:04:04
I have a Cub Cadet 1320 and the engine runs smoothly when first started but begins to accelerate then decelerate (lurching if you will) when under load. t
Any ideas on why this is happening??
JT
12-03-2007 15:06:42
 Re: Cub Cadet engine lurching in reply to akper, 12-03-2007 15:04:04
You have a fuel startvation problem. normally this does not happen under load, just under a no load condition.
akper
12-03-2007 15:16:35
 Re: Cub Cadet engine lurching in reply to JT, 12-03-2007 15:06:42
that's what i was thinking but wasn't sure, could it be a fuel filter or bad gas problem as well??
JT
12-04-2007 08:38:12
 Re: Cub Cadet engine lurching in reply to akper, 12-03-2007 15:16:35
It could be, I would probably pull the carb bowl off and look for a little bit of dirt or something. If the gas is older, and the fuhel filter has not been replaced in a while, I would definatly start there.
jim
