Case 444
No Spark
Scott Rogers
10-12-1999 07:34:17
I have a 14 horse Kohler, that when I was mowing backfired several times and then quit. Coil wires are all tight and the wires appear to be in good shape. Any suggestions as to where I should start to look for the problem would be appreciated.
Thanks!
Paul
10-12-1999 09:20:54
 Re: Case 444 - No Spark in reply to Scott Rogers, 10-12-1999 07:34:17
Check your points. They are supposed to be set at 20 thousandths. They are located in the little box with top and bottom screws below and to the left of the carb. Make sure they are not broken, as the plastic tends to wear and break. Easily fixed if they are the problem.
Paul
roy
10-12-1999 19:01:17
 Re: Re: Case 444 - No Spark in reply to Paul, 10-12-1999 09:20:54
I've found that the condenser is usally bad after a series of backfires. Maybe it's time for a general tune up; (plug, points and condenser.)
Good luck with your adventure. Roy
Brad
10-13-1999 13:35:02
 Re: Re: Re: Case 444 - No Spark in reply to roy, 10-12-1999 19:01:17
If you ever want to sell it, drop me a line.
