Replacing crank seal on Tecumseh HH120
queen of spades
01-03-2008 17:22:54
Is it necessary to replace the crankshaft seal if the motor comes apart? The seal wasn't leaking before.
queen of spades
01-03-2008 18:16:32
 Re: Replacing crank seal on Tecumseh HH120 in reply to JT, 01-03-2008 17:22:54
How do I remove them? I"m afraid of damaging the metal around it.
supergrumpy
01-04-2008 05:45:11
 Re: Replacing crank seal on Tecumseh HH120 in reply to queen of spades, 01-03-2008 18:16:32
the rubber in the seal gets brittle and can leak after being disturbed, fairly easy to change while motor is apart, after you get burned by not changing one you start changing them every time
they make seal remover tools, lever kinda end on a screwdriver, or you can drill small hole in metal side of seal then use ice pick or pin punch to pry seal out
JoeK(WI)
01-03-2008 18:59:33
They are simply friction fitted.Often they can be twisted out with a med size channelock pliers from the outside.If more force is needed a socket,slightly smaller than the seal and an extension can be use to drive it out.KEY ISSUE,patience is imperative,a gentle tap,tap,tap should always be used.WHACK,WHACK,WHACK is for other pursuits.Never try to bull a small engine case as they can be quite fragile. Without a seal driver to install the seal,oil it,place it on the hole and try to manually get it started levelly into the hole.Once started,place a small block of wood over the seal,and tap it into place.Check every few taps for straitness and correct with taps on high side.
JT
01-03-2008 17:53:26
 Re: Replacing crank seal on Tecumseh HH120 in reply to queen of spades, 01-03-2008 17:22:54
For the small price of them, replace them, 50% of the time they will leak after being disturbed.
Jim
