Backfiring John Deere
Tedoh
01-06-2008 12:12:29
I've got a 1991 John Deere F710 with a Kawasaki FC540V-AS12 engine. 2 weeks ago when I parked it it was running fine. Tried to start it yesterday and all it would do was backfire out the exhaust. Today it is backfiring out the carb. Not rolling hard or kicking back. Plenty of blue spark through the plug. Valves opening and closing. Has 125# compression. I need to know the valve settings, air gap for the coil, and sparkplug gap. Any suggestions will be greatly appreciated. Thanks, Ted.
Chevy65
01-09-2008 04:23:01
 Re: Backfiring John Deere in reply to Tedoh, 01-06-2008 12:12:29
Sounds to me it has a bad ingnition igniter or as some call the trigger
Its a small silver box about size of a quarter with a single white wire going to it
Only early units had this Later unit it was made into coil
Coil air gap .012 should be good
Good Luck Gary
Mail me if u wish
Tedoh
01-08-2008 02:30:58
Still trying to figure this thing out. I've changed card soleniod, checked flywheel key, checked valves, both working and set at .006. Don't know if the gap is right or not. Also changed spark plug. What do I try next? Any more suggestions are welcome. Thanks again, Ted.
NOS88
01-07-2008 13:24:55
Try a new spark plug before you get to involved. Sometimes I have had this problem and a new plug has fixed it. Cheap fix!
farmerjohninpa
01-06-2008 20:06:28
fixed quite a few of them rascals last 2yrs.,,has been that dang electric solenoid on carb bowl every time.
2cents
01-06-2008 14:35:27
Had a chainsaw do that and it was a bad ignition module, I dont know what your kaw has but it sure sounds the same.
El Toro
01-06-2008 13:05:51
Sounds like it may be out of time. Hal
