kolher 301 12 hp
A. Cosh
01-17-2008 11:03:50
how to set the govoner on this and if its broken or not ?
Kentb of SWMO
01-17-2008 17:35:46
 Re: kolher 301 12 hp in reply to A. Cosh, 01-17-2008 11:03:50
With the engine NOT running, loosen the pinch bolt on the lever that is on the govener shaft. Move this lever that is connected to the throttle shaft of the carb to the left, wide open position. Hold in this position and turn the govener shaft as far counter-clock wise as it will go. Now tighten the pinch bolt. If you have NO govener action after this adjustment you have internal peoblems and the ONLY way to fix it is to TOTALLY disassemble the engine. I went through this on a K-341 for my Father in late summer. On Dad's engine the govener linking spring linkage was not set-up right which caused the engine to be over reved which EXPLODED the balance gears. The flying pieces damaged the govener gear and broke the dipper from the rod.
Kent
Acosh
01-20-2008 08:05:38
 Re: kolher 301 12 hp in reply to Kentb of SWMO, 01-17-2008 17:35:46
Thanks for the info. I have internal problems.
