wheel horse hydro problems
ole roy
01-24-2008 06:56:19
I have a wheel horse 518 H produced between 1988-1989. the hydrostatic works fine when cold, as you run it the ground power diminishes especially reverse what is my problem ? & how do I fix it ?
ole roy
01-24-2008 13:58:31
 Re: wheel horse hydro problems in reply to ole roy, 01-24-2008 06:56:19
to roger in iowa has no filter there is a lever supposed to make it free wheeling dose'nt seem to want to work
ole roy
01-24-2008 14:08:44
 Re: wheel horse hydro problems in reply to ole roy, 01-24-2008 13:58:31
to JT garsh I hope you are right never even crossed my mind my other tractor is "shaft drive" thank you and roger in iowa I will keep you posted
JT
01-24-2008 09:57:34
Roy,
I would look at your drive belt, If it has not been looked at for a while, probably is getting a little glazed and worn. Does it make any kind of howling noise when it slows down? Normally if it slows down and makes no noise, it is a slipping belt, if it is howling as it slows down, then you probably got some pump issues.
Jim
Roger in Iowa
01-24-2008 09:09:40
If it works better cold than hot, it would indicate worn parts in either the hydro pump or motor or both.
I would start by changing the oil and filter. (cheap try to fix)
If worse in reverse, the reverse speed is usually half or less of forward. So if half of forward is as bad as full reverse, again it sounds like worn parts. If half forward is better than full reverse, it might be trouble with the reverse relief valve, if it has one. Some do not have relief valves.
Do you have a method of allowing you to push tractor without engine running by depressing two by-pass valves? If so, make sure they are not partially depressed?
Roger in Iowa
ole roy
01-27-2008 11:11:07
  attention Gab re;: wheel horse hydro problems in reply to Roger in Iowa, 01-24-2008 09:09:40
I feel so stooopid !! The way I wrote in the forem [to gab from ole roy] Not explaining myself as to wether the resovoire needed expansion room or not.Excuse me for spelling stooopid wrong,cause I know it only has 2 o"s in it, HA! HA!
