AC T811 Rear PTO
Karl Hulse
01-28-2008 12:05:42
I am looking for a manual which describes the use of the rear PTO engagement for my AC T811 garden tractor. It looks as though a pulley needs to be added to align with the cutout at the rear of the tractor.
RaysLane
02-02-2008 19:50:56
 Re: AC T811 Rear PTO in reply to Karl Hulse, 01-28-2008 12:05:42
Typically you put a second pulley on that same shaft. You can just move your existing mower-drive pulley over, but you need a double pulley-one for the mower, one for the hydraulic pump.
Simple Tractors (on the main CLUB page), lets you print any AC manual. Put your model # in.
Karl Hulse
02-04-2008 10:07:53
 Re: AC T811 Rear PTO in reply to RaysLane, 02-02-2008 19:50:56
Thanks for the information.
LWS
01-31-2008 18:39:21
If you take the MFG # for the tiller and go to the simple tractors .com site and go to the home page there is a box to put your # in it says MFG for finding manuals and it will give you owners and parts manuals.
les_from_syracuse
01-29-2008 09:36:29
You might be able to find info at simpletractors.com. On my Simplicity 7112 I have to move one of the pullies to different holes depending on what I'm hooking up.
Karl Hulse
01-29-2008 09:58:30
 Re: AC T811 Rear PTO in reply to les_from_syracuse, 01-29-2008 09:36:29
Thanks for the input. I've done some research on Simple Tractors, but haven't found it yet. I know the manual is out there somewhere. I'll look closer at the pulley setup and see if there's any adjustment as you mentioned. Thanks again.
les_from_syracuse
01-29-2008 12:48:32
 Re: AC T811 Rear PTO in reply to Karl Hulse, 01-29-2008 09:58:30
What are you hooking up on the backend? I have a tiller for the back of mine and a mounting kit had to be added which consisted of brackets and a pulley or two.
Karl Hulse
01-29-2008 14:05:18
 Re: AC T811 Rear PTO in reply to les_from_syracuse, 01-29-2008 12:48:32
I'm actually planning on mounting a belt driven hydraulic pump to power a front end loader (I purchased the plans for the front end loader from>Link
I>Link plan to bolt on a small platform on the back for mounting the pump and then connect it to the pto. I'm sure it'll be more complicated once I get started.
