Any Case 444 Wiring Experts Out There?
chincha805
02-01-2008 17:15:27
I replaced the stator on my k321, but i am stuck on the wiring. There are 3 wires coming out of the stator , i no two go to the trigger (solid state ignition) but not sure which one of the two go to which termial on the trigger. and then one goes to coil? i have a parts manual but in is for a 1976 , mine is a 1969, and the wiring diagram is diffrent.
El Toro
02-01-2008 18:15:40
 Re: Any Case 444 Wiring Experts Out There? in reply to chincha805, 02-01-2008 17:15:27
third party image
Don't your wires from the stator go the rectifier
(regulator)?. You have AC voltage from the stator
to the rectifier that convert your AC voltage to DC and that charges your battery. Here's a rectifier with wire connections from the stator.
Hal
chincha805
02-01-2008 20:38:05
 Re: Any Case 444 Wiring Experts Out There? in reply to El Toro, 02-01-2008 18:15:40
Thanks , thats excactly what i was looking for.
Trailer Trash Tractors
03-23-2008 20:00:33
 Re: Any Case 444 Wiring Experts Out There? in reply to chincha805, 02-01-2008 20:38:05
That schematic helps mee too ! Thank you
