Sears Suburban voltage regulator
queen of spades
02-02-2008 20:32:27
Sears no longer offers voltage regulator on their parts site. Can I use a voltage regulator from a different tractor, or do I have to have an exact replacement?
Trailer Trash Tractors
03-21-2008 21:18:49
 Re: Sears Suburban voltage regulator in reply to queen of spades, 02-02-2008 20:32:27
I have a Bolens 1556 with a Tecumseh engine HH150 17001 The Regulator is Solid State
Had an old Sears Suburban with Tecumseh 16 HP regulator looked same as Bolens one
You didn"t specify Solid State, or points
regulator, Hope my numbers help, it"s awful
what Sears does to numbers
JT
02-04-2008 06:35:28
You have a standard Delco Remy regulator that is not made for any one particular application. If you have any place around that is an actual auto parts or small enngine shop or starter rebuild shop, they can get you one for around $35.40.00. If you need any other help, let me know. Take your old one with you to get the correct mount and such. You might also take yours apart and clean the contacts.
Jim
Dannie1
02-04-2008 02:15:06
143.606022 is A Tecumseh H70-130071
queen of spades
02-03-2008 13:00:49
 Re: Sears Suburban voltage regulator in reply to Kentb of SWMO, 02-02-2008 20:32:27
JT said: (quoted from post at 13:06:49 02/03/08) What is the part number you need? They discontinue a lot of parts that are still available through OEM.
Jim
Part Number: Part Description: Model Number:
2257R REGULATOR, VOLTAGE 917.25370
JT
02-03-2008 09:06:49
Jim
joe csuti
02-03-2008 02:47:21
You could try taking sears eng mod#,hp & eng mfg info to local dealer & have them crossref eng mfg to sears# and get mod#,type or spec# and lookup vr part # from there in parts list for eng,you might also try posting sears eng mod# here,maybe on of the guys has eng mfg to sears cross ref.If this is a Techumseh mod HH100 or HH120 eng,a lot of the Kohler vr's will work with same,the important thing is to get one with a current rateing equal to or higher than the old one & output rateing of alt on eng.
lucas boy
02-03-2008 06:14:39
 Re: Sears Suburban voltage regulator in reply to joe csuti, 02-03-2008 02:47:21
i found that one in an aftermarket catalog , stens or rorary i think,. your local mower shop may have those catalogs.lucas
ams
02-03-2008 18:06:25
 Re: Sears Suburban voltage regulator in reply to lucas boy, 02-03-2008 06:14:39
the engine number is 143.602022
