suddenly no spark in 214
6U684
02-12-2008 14:08:17
Blowing the everlasting snow out my NE Iowa rural home setting when the trusty JD214 quits with not a sputter, no unusual manuevering on my part. No spark, replaced condenser with one off a 212 that was running last fall. Still nothing What now, coil?Your suggestions? Thanks, Leonard
6U684
02-15-2008 17:21:04
 well it was the coil in reply to 6U684, 02-12-2008 14:08:17
Points were good but replaced them anyway, new condenser, still no spark. replaced coil, bingo! Thanks guys. Leonard
Bendee
02-12-2008 21:08:16
 Re: suddenly no spark in 214 in reply to 6U684, 02-12-2008 14:08:17
clean battery terminals and leads first,then try.
a common occurrence on my Fergy.may help.
JT
02-12-2008 15:00:17
Do you still have 12v to the pos side of the coil? That would be first thing to check, then, check to see if you have 12v to points when they are closed. then make sure points are clean.
lucas boy
02-13-2008 07:01:08
 Re: suddenly no spark in 214 in reply to JT, 02-12-2008 15:00:17
that coil needs at least 8 volts to fire,so be sure voltage is up when cranking and running . used oem point and condenser . i have not had luck with the aftermarket ones.
