Delco-Remy amp output (Sears SS12) - want to add work light
queen of spades
03-03-2008 17:54:00
Does anyone know how many amps the Delco-Remy starter makes for SS12 tractors?
My front headlights are 35watts each and the little taillight is tiny, not sure how much. I bought the smallest work light I could find, which is 35 watts.
I've searched for days and haven't been able to find out this info. I need it to put out at least 10 amps, but I'm afraid it only makes 7amps (that is a guess by someone on another board).
queen of spades
03-04-2008 06:11:09
 Re: Delco-Remy amp output (Sears SS12) - want to add work... in reply to queen of spades, 03-03-2008 17:54:00
I finally found out that my starter/generator puts out 15 amps. So I added the work light last night. I still need to wire in a fuse but it's almost ready:
third party image
third party image[/url]
Kentb of SWMO
03-04-2008 05:52:25
Most of the regulators for the S/G"s have a fourth terminal on the regulator marked "L". This is where to connect your lights. The light will only work with the engine running but the lights will have less affect on the battery charging when connected to the "L" terminal.
Kent
Annn
03-03-2008 23:41:05
Most starter/generators were rated for 15 amp output, with the engine running about 3400-3600 rpm.
Remember with all the lights that you add, to leave a few amps to charge the battery with.
Also, if you have a battery powered igntion, you need to leave a couple amps for that to use also.
rustyj
03-03-2008 18:43:24
Those LED lights put out a lot of light, so i've been told, and don't draw a lot of power.
