1282 Hydro No go! ( But it will!)
Andy f
03-17-2008 09:35:07
To R Bendel and Jay IH man...THANK YOU!!!
My original post 1282 Hydro NO go pg 5! I found the problem. The linkage,Trunion plate, the springs are Missing! Need to get new ones and check the plate for wear, and iregularites. I got new cub Cadet fluid(2 gallons) new filter, new orings,new suction pipe(leaking),gaskets.I will oder new damping springs today.
I cant work on it yet because the yard is a swamp, and I have to get it in the garage. I cant thank you guys enough, for your help! I cant wait to start cutting grass again with my old 1282! Andyf
R Bedell
03-18-2008 06:56:47
 Re: 1282 Hydro No go! ( But it will!) in reply to Andy f, 03-17-2008 09:35:07
Andy:
I agree with David. I think you would be farther ahead by buying a good used Hydro.
That Trunion Yoke is a PITA to remove and/or replace.
JayIHMan
03-17-2008 20:23:11
Andy, That is good news...helpful hint...hop on ebay these are pretty common to find in good used condition. I buy alot of cub stuff off of ebay and you can"t beat the prices if you bid right. Do a completed listing search for part you need to see what market price is. JayIHMan
Andy F
03-18-2008 03:41:05
 Re: 1282 Hydro No go! ( But it will!) in reply to JayIHMan, 03-17-2008 20:23:11
Jay, The only thing that worrying me is in order to get that truuion out to do anything is to open the transmission in order to pull the pin to remove the shaft. The truion is actually broke,theout side edge is gone. Iwas wondering if some ever came up with an alternate fix . I know I am grabbing for straws but my back and hps are in bad shape and withn the economy going to hell, I am in afix. Thank you again for your imput!
Andy
stronics
03-18-2008 04:15:12
 Re: 1282 Hydro No go! ( But it will!) in reply to Andy F, 03-18-2008 03:41:05
I'd, given your circumstances shop ebay for a good used hydro unit with linkage and check valves with a bullet proof return policy. For less than $100 you could be back in business. If you were close to NE Ohio I could do it for you.
It can be a handful repairing it if your not doing it a lot.
Gaskets and seals would cost almost the same.
David
