66 yardman voltage reg. wiring
Rick A
03-29-2008 16:27:07
Trying to help neighbor with 1966 yardman 16hp hydrostatic tractor. All the wires to the voltage regulator were disconnected when purchased. I contacted MTD and they thought the model number could be 136-390 but did not have any other information. Any help finding a wiring diagram for the voltage reg. on this tractor would be appreciated.
Rick A
03-31-2008 00:24:23
 Re: 66 yardman voltage reg. wiring in reply to Rick A, 03-29-2008 16:27:07
Thank you both for the information. I removed some paint from the legs on the voltage reg. and found the marks. I'll wire everything up on monday and see if it charges.
Kentb of SWMO
03-30-2008 11:13:54
If a Starter/Generator set-up, you connect a wire from the "F" terminal on the starter/generator to the "F" terminal on the regulator. A 16 gauge wire should be heavy enough. The you connect a heavier 14 or 12 gauge wire from the "A" terminal on the regulator to the "A" terminal on the starter/geberator. You also connect a heavier wire, 10 gauge should do, from the "A" terminal on the starter/generator to you starter switch or solenoid. The system SHOULD be 12 volt NEGATIVE ground. Kent
Tom Arnold
03-29-2008 16:56:18
It often helps if you identify the motor but I'm going to guess that it's a cast iron Briggs with a start/gen unit on the side of it. If so, then it likely has a three terminal regulator and those are often marked to indicate Field, Armature and Battery connections.
