headlight insert
70D
04-09-2008 15:24:30
Can some one tell me what bolts and if there is spacers on the grill insert or headlight insert on my 1972 110 JD I took it apart last year and have forgot how it goes Thanks in advance 70D
Bob
04-09-2008 19:15:22
 Re: headlight insert in reply to 70D, 04-09-2008 15:24:30
Third Party Image
KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 AM31656 HOOD 1 (LESS TRIM STRIPS) (ORDER STRIPS AS REQUIRED, SEE PAGE 70)
2 AM33839 PIVOT 1 L.H.
3 AM33838 PIVOT 1 R.H.
4 M46253 STRAP 2
5 AM32324 PANEL 1
6 JD5273 DECAL 2 (SUB JD5603)
7 M44232 GRILLE 1 -272000
M46181 GRILLE 1 272001-
8 AM33851 COWL 1 -272000 L.H. (NO LONGER AVAILABLE)
AM34847 COWL 1 272001- L.H. (SUB FOR AM34337)
9 M46330 COWL 1 -272000 R.H. (NO LONGER AVAILABLE)
AM34844 COWL 1 (A) R.H. (8 HP) (SUB FOR AM34399) (NO LONGER AVAILABLE)
AM34846 COWL 1 (D) R.H. (10 HP) (SUB FOR AM34338)
10 19H1731 CAP SCREW 4 -272000 3/8" X 1"
24H1303 WASHER 4 -272000 13/32" X 11/16" X 0.065"
12H310 LOCK WASHER 4 -272000 3/8"
14H1076 NUT 4 -272000 3/8"
19H1936 CAP SCREW 4 272001- 3/8" X 3/4"
12H310 LOCK WASHER 4 272001- 3/8"
11 03H1268 BOLT 4 5/16" X 3/4"
24H1136 WASHER 4 11/32" X 11/16" X 0.065"
12H291 LOCK WASHER 4 5/16"
14H611 NUT 4 5/16"
12 M44395 BOLT 1
13 12H291 LOCK WASHER 1 5/16"
14 14H611 NUT 1 5/16"
15 21H1020 SCREW 2 0.190" X 1/2"
12H295 LOCK WASHER 2 0.190"
14H778 NUT 2 0.190"
16 M40748 LATCH 1
17 21H1300 SCREW 2 0.190" X 3/8"
14H778 NUT 2 0.190"
18 M40747 LATCH 1
19 STRIP 1 (ORDER AS REQUIRED, SEE PAGE 70)
20 AM32325 PANEL 1
21 N10010 CLIP 1
22 AM31965 WIRING HARNESS 1
23 M42538 RING 2
24 AM31282 LAMP 2
25 37H69 SCREW 4
26 M43195 RETAINER 2
