Case 446 engine problem
Carl Herceg
10-25-1999 14:17:07
Hi all,
After mowing with my Case 446 lawn tractor for about half an hour, the engine starts spitting out a huge cloud of smoke from the exhaust pipe. I stopped the engine and looked under the hood and noticed the air cleaner assembly was filled with oil. I could run the tractor for about 5 minutes after it sat for about 5 before the same thing happened. Any ideas what's causing this?
Thanks,
Carl
Mark
10-26-1999 16:11:56
 Re: Case 446 engine problem in reply to Carl Herceg, 10-25-1999 14:17:07
Three things come to mind. Oil level is to high-crankcase vent\filter is plugged-it is under the small hose on the bottom of the air cleaner or a piston ring or skirt broke.
Dave
10-27-1999 04:19:55
 Re: Re: Case 446 engine problem in reply to Mark, 10-26-1999 16:11:56
Mark hit the nail right on the head
