110 JD
70D
04-28-2008 11:40:09
Yes I posted a noted a coulpe weeks ago and got back a reply Thank you but I have another Question on a John Deere 110 is there more than one kind of hinging system The one that was posted for my reply shows that the front header does not move when the hood is open but mine looks as if the whole thing moves as the hood opens front header moves too(lights) or am I missing somthing it has been over a year and I have forgot how I took it apart and don"t want to break my new hood and header
70D
04-28-2008 13:53:35
 Re: 110 JD in reply to 70D, 04-28-2008 11:40:09
So then if My tractor is a 1972 do I need part AM33839 Lh pivot and same for right side I bought a new hood and had threw the old one away so don't remeber this on there Thank once again
Butch GA.
04-28-2008 16:23:04
 Re: 110 JD in reply to 70D, 04-28-2008 13:53:35
70D my parts book goes from 1968 to 1971 and I do not show that part number you have listed so your could be different from mine. I do know I have to be careful when I open my hood because it hits the grill screen.I broke mine once and repaired it so far so good.
70D
04-28-2008 13:55:24
Of course I didn't do the link right but they are a bracket that has a hinge pivot on them
steve in in
04-28-2008 13:07:30
The 1968 through 1974 header panel moves with the hood. The panel is prone to crack if you aren't careful removing and replacing the hood. The hood fits pretty tight around it.
You also don't want an obstruction, say, a partially removed grill in the way when you open the hood. Many panels have probably been busted that way.
The 1963 through 1967 110 tractors did not have the header or headlight panel.
Steve
Butch GA.
04-28-2008 12:32:01
70D The black header that can hold the head lights or left blank moves with the hood on my 1970 and 1971 It"s heald in place with 4-1/4" short carriage bolts
