Bolen's Ridemaster
greenbeanman in
04-30-2008 05:30:49
I posted three weeks ago that I had purchased a Bolen's Ridemaster. I'm putting out a very large garden this year so have been too busy to work with it. Yesterday I did take the time to temporarily install a Lauson engine made by Fairbanks Morse. I will repower it when I have more time and can do it right. I needed it powered for a parade this weekend, hence the temp Lauson installation. The Lauson appears more time appropriate even if not a Wisconsin that came on the units. While it is a pretty close color to what a Ridemaster should look like it isn't quite the John Deere green they unit was painted when I bought it.
With the drive wheels pivoting as the do the unit turns so short the back sulky tire pivots in it own footprint. Can you say up one row and down the next without a large aisle to turn around in? I look forward to cultivating with it.
When I have more time I'll upload some photos to a site and post back.
jdemaris
04-30-2008 15:16:36
 Re: Bolen's Ridemaster in reply to greenbeanman in Kansas, 04-30-2008 05:30:49
I never heard of Fairbanks-Morse making any Lauson engines. Lauson was a division of Tecumseh-Power Products since the 1950s. Are you using an engine that predates Tecumseh ownership?
The original Wisconsin engine shouldn't be that hard to find for your Ridemaster - they were used on many things.
04-30-2008 18:31:07
 Lauson Fairbanks-Morse in reply to jdemaris, 04-30-2008 15:16:36
The engine shroud has an original Lauson decal on it and on the side of the shroud is a riveted on name plate showing Fairbanks-Morse.
It is an old engine. I'll try to remember to get more info off of the F-M plate. Maybe it shows a model number.
I would actually guess that the engine pre-dates the 1950s, but I don't know about pre-dating Tecumseh.
My Ridemaster will be a machine put to great use hence the desire for something other than a Wisconsin. I'm actually thinking of powering a hydraulic pump and then use a hydraulic motor to power the tranmission. That way I can have great control over speed. I plan to drop potatoes down a tube into furrows, and possibly even transplants. Might also drop peanuts as I am afraid my planter would tear up the seed too badly.
Thanks for the insight, I'll see if my digital camera can capture the Fairbanks-Morse plate and the Lauson decal.
jdemaris
05-01-2008 06:21:16
 Re: Lauson Fairbanks-Morse in reply to greenbeanman in Kansas, 04-30-2008 18:31:07
I've got two Ridemasters and like them just the way they are. The OEM Wisconsin is a very good engine and better then anything Tecumseh ever put out at the time.
In regard to the Fairbanks Morse sticker - many pieces of equipment that Fairbanks Morse sold used Tecumseh/Lauson engines and that's probably why the sticker it there.
05-01-2008 15:33:19
 You were right in reply to jdemaris, 05-01-2008 06:21:16
I do believe that you were right about the Fairbanks, Morse just being an application user of the Lauson engine in question.
The riveted on data plate clearly states the engine is Made By The Lauson Company, New Holstein, Wisconsin.
The engine is Type TLC-349
Number 8-42054
Order_____ _____ _____ ___ (none given)
I find engine manuals on Ebay for the TLC model of engine.
A blurb of history provides this: "In 1895, the brothers Lauson developed the first Lauson gasoline engine. In the process they built the company that became Tecumseh Products Company in 1956. Page 13 here:>Link
I>Link am wondering if the TLC-349 might indicate a manufacturing date of March 1949? I suppose it could also indicate a 3 hp engine.
Today I mounted a different engine pulley on the Lauson and drove it around quite a bit. Even put the 5 shank sweep cultivator down and did a little digging.
Are your reverse discs in good shape? Is there a source for replacements if I did go back to a Wisconsin engine? Do you know of a source for Ridemaster decals or where I could at least get a good view of one in order to produce my own version? Last I knew Hank was out of them.
What equipment do you have for yours?
Thanks
