11 HP B S
Ed K
05-03-2008 05:55:43
I have a 11 HP B&S engine that I am rebuilding. There is 2 counter balance gears on the inside on both sides of the crank. These run off the crank. I assume these need to be in time with the crank. My question is what is the proper timing for these?
BJ
05-03-2008 15:59:30
 Re: 11 HP B S in reply to Ed K, 05-03-2008 05:55:43
I found the answer this morning only cost me 20 dollars for a manual, unwapped it right at the counter and had my answer in about 1 minute asked the parts guy for a refund on the manual but he was not interested in that idea at all but I digress on your crankcase cover there are 2 small screws behind the counterweights remove them and then use 2 rods 1/8 inch in diameter (drill bits work good) to pin the counterweights in place you will have to rock them back and forth a bit to find the holes, then set the piston at Top Dead Center (the keyway in the crankshaft will be at 12 O'clock) then slide the cover back on
joe csuti
05-03-2008 07:47:24
Check reply to BS Question from El Toro further down page,see if this matches your eng.
