Starter on JD317
yak651
05-05-2008 08:04:52
Is there a way to test the starter? I have a JD317, thought the battery was dead as it wouldn't crank, took the battery to be checked and it was weak but not dead. I got it charged up, but nothing. The next day I try it and it cranks over and starts. I had it shut off and started about 4 times that day with no problems. The fifth time I tried to start it nothing. I put it back on the charger and still nothing. Let it sit for a day and then it cranked again. Now nothing. The starter on this machine is hard to get at, so would rather test it somehow if possible before yanking it off. Figure it is either the starter or the safety switch on the seat, I tried bypassing the safety switch and that didn't seem to make a difference. Any ideas?
Thanks for your time.
El Toro
05-05-2008 16:43:41
 Re: Starter on JD317 in reply to yak651, 05-05-2008 08:04:52
It may be a bad starter solenoid that's not engaging the bendix. Hal
Bob
05-06-2008 07:06:28
 Re: Starter on JD317 in reply to El Toro, 05-05-2008 16:43:41
They have an inertial starter drive, NOT a "positive shift" setup, where the dive is engaged by the solenoid..
Bob
05-06-2008 14:15:14
 UHHHH.... in reply to Bob, 05-06-2008 07:06:28
UNLESS that one has had the "Onan swap"!
yak651
05-06-2008 18:57:01
 Re: UHHHH.... in reply to Bob, 05-06-2008 14:15:14
Bob said: (quoted from post at 14:15:14 05/06/08) UNLESS that one has had the "Onan swap"!
I think I may have figured it out, I think it was the neutral switch not being made. It worked tonight after playing with it, so I'll see if it works again tomorrow, if so that must have been it.
Thanks for the ideas.
Bob
05-05-2008 08:29:55
Connect a set of "jumper cables" to a car or truck.
Ground the black clamp to a good ground on the 317's engine. Touch the red clamp to the STARTER SIDE stud on the starter solenoid... does it spin that way?
(You may need to remove the battery and the battery tray from the 317 to get at the starter solenoid.)
yak651
05-06-2008 11:37:31
 Re: Starter on JD317 in reply to Bob, 05-05-2008 08:29:55
Thanks, i'll give this a try this weekend
