I did a dumb thing, glad I spotted it !
Trailer Trash T
05-05-2008 20:20:45
I couldn't find a filter for my Bolens 1556,
so I spun off the old one, and dumped out the oil. I spun the filter back on, took a second look at the pan holding the used oil, and realized my folly. By dumping the filter, I dislodged the dirt. Won't start it until I get a filter.
Called MTD, they insisted trans [ eaton 10 ] was made by either tecumseh or hydro gear, neither co. had info. Needless to say, now I * need * a filter. ** Don't do what I did, leave the dirt in the filter until a replacement is on hand ! **
rick williams
05-31-2008 12:02:49
 Re: I did a dumb thing, glad I spotted it ! in reply to Trailer Trash Tractors, 05-05-2008 20:20:45
The Eaton 10 was made by the Eaton Company . Is the filter you need for the hydro or the engine ?
Link
05-07-2008 20:25:18
Engine is 15 HP Tecumseh single cyl.
Bob
05-06-2008 07:05:18
WIX only lists 2 filters for the Bolens line, 51307 and 51410.
BOTH have 3/4"-16 threads.
The 51410 has NO internal bypass.
The 51307 has an internal bypass that opens @ 13 to 19 PSI.
The sizes are pretty close, with a gasket OD of 2.834".
If the thread and gasket sizes seem correct, cut your old filter open, and look for a spring-loaded bypass, then decide which filter to use, based on the presense or abcense of the internal relief.
El Toro
05-06-2008 04:13:00
If there's a number on the old filter your local auto parts store can probably cross-reference the number. Which engine is used on your tractor? Hal
05-08-2008 18:41:07
 Re: I did a dumb thing, glad I spotted it ! in reply to El Toro, 05-06-2008 04:13:00
Numbers illegible, Fluid dissolved ink, can rusty Spin on is white, can read, what must be " Canada " No brand name, I like the Wix plan, buy both, cut old one, use ' right ' one.
Prolly going to try a Fram PH 16 to grab the grossest dirt, before going to WIX, thanks for help
