Briggs and stratton ignition coil
ACPhil
05-18-2008 13:03:41
I recently saved an old Huffy riding mower from an undignified fate. On close inspection, I found that a friendly mouse family had dinner on the coil high tension lead. My question: I have a new ignition coil for the pointless ignition system. Do I have to change to the newer style flywheel to go with this new coil? Better yet, what do I need to use this new style coil? Does anyone know of anyone making decals for these old Huffy riders? Thanks again, Phil
T.R.K.
05-22-2008 19:15:52
 Re: Briggs and stratton ignition coil in reply to ACPhil, 05-18-2008 13:03:41
I had a friend who worked at a graphics shop make some Huffy decals (The oval decal for the '60s models.)
I also put a magnetron retrofit kit on the engine and did not change the flywheel. It worked fine. Mine was the 100000 model series. I was having to take the whole top of the mower off the change the points and that quickly got old.
Enjoy your Huffy!
Kentb of SWMO
05-18-2008 13:29:08
Depending on the size of the engine and the code number. You may be able to bolt the Magnetron soil on and go. Most smaller aluminum engines with a two legged coil do not need the flywheel change to use the Magnetron coil. If you will post your MODEL NUMBER, TYPE NUMBER, CODE NUMBER I can tell for sure.
Kent
Jim H. SW-PA
05-19-2008 06:15:33
 Re: Briggs and stratton ignition coil in reply to Kentb of SWMO, 05-18-2008 13:29:08
I have put automotive coils on outside of engines. eliminating coil wire that comes out of engine cover. To do that tho an extra + wire on a switch is needed.
