Craftsman mower idle problem
Joseph Schneidi
10-30-1999 15:30:40
Every older craftsman has an eratic idle. If you shake the tractor it can stall. I rebuilt the carb on a number of them. It never goes away. Whats up with this?
Mike Bearden
09-28-2000 13:34:26
 Re: craftsman mower idle problem in reply to Joseph Schneidinger, 10-30-1999 15:30:40
More times than not, you will find that the float seam is leaking and slowly filling up the float on the brass float models & especially on the GT's. You might also check to make sure your float level is within spec. The only reason a motor would stall from shaking it {fuel related anyway} is from excessive fuel levels. Even the bakeolite plastic floats will deteriate and start filling up with fuel.
