Case 446 hydro snowblower belt.. Size?????
truck
11-13-1999 15:28:36
Am trying to install the case 48 inch snowblower that came with the tractor a neighbor has. They bought the tractor this summer and the previous owner took two months to come up with all the parts and the supposed correct belt, which is too short, and probably is the one for the mower deck. Anybody just happen to know part numbers or dimensions on the snowblower belt? Any other things we should look out for getting this ready for winter besides tune up and oil? Already discovered 2 missing manifold bolts and replaced the choke cable where it belongs.. Straightened out a lot of bent parts.. ( Hint.. never let somebody who is not a good driver try to drive a 446! They can get away from them in a hurry!And they are no match head on with an equipment trailer!oops!)Thanks! I need to get this thing out of the shop so I can get the real tractors back in!
Steve
11-13-1999 18:52:41
 Re: Case 446 hydro snowblower belt.. Size????? in reply to truck, 11-13-1999 15:28:36
part # for the smowblower belt is C23950 for a J80 an 84 81.625" for a K80,K84,L80, L84 blower is C23539 80.5" hope this helps email if have any other ? Lantz@friendlynet.com
Bobcat
11-13-1999 18:14:35
Use the following info. as a last resort truck.
I recently acquired an L84 snowblower for my 446... not used it yet. Bought it from a guy that said the snowblower belt and mower deck belts are the same. If so, my mower deck parts manual shows the belt being a CASE P/N C23359.
I have a note in the same manual stating the belt size as 1/2" x 1/2" x 64 1/4" o.d.
Hope this helps you get back under the big ones.
