127 Cub Cadet lift parts needed
B. Abrams
11-16-1999 13:07:12
Have a model 127. Just added snow blower, getting to be threatening weather. Need the bracket that u-clamps to lower part of right hand lifting lever that blower lift rod goes into. Also would like to add the spring assist that was an option way back in 1968. The assist was adjustable via a hex head above the hitch and to the right. Also, this being hydrostatic, is there a port that I can pipe into to use the hydrostatic transaxle as a hydraulic power unit for cylinders, etc.? Please help! Thank you
JAMSHAID ILYAS
03-13-2001 12:51:18
 Re: 127 Cub Cadet lift parts needed in reply to B. Abrams, 11-16-1999 13:07:12
Dear sir, we are installing and mantenes in pakistan.we need lifts and escalators spair parts.Are you send me some catalogues of related lifts parts[motors gears guid rails door drive doors and other parts.
Paul Stein
04-26-2000 19:04:25
I don't know about either the spring assist or if you can tap int the hydraulics, but I have a 147 with a failed electric lift and would like to know if you find about either as I would like to retofit my 147 w/ hydraulic lift to replace the electric
Ron Keller
11-18-1999 05:41:34
Try Scott at Madson's service they have lots of used parts. 1-920-773-2661.
