Craftsman tiller clutch
Robert(AL)
11-28-1999 15:23:25
Clutch stuck on Craftsman rear tine tiller.
In order to get to it, the wheel has to be pulled
and it is rusted to the shaft and no way to get a puller on it. Anyone have any ideas on how to repair the clutch and pull the wheel.
Thanks in advance,
Robert
wstoner
07-09-2005 08:14:33
 Re: Craftsman tiller clutch in reply to Robert(AL), 11-28-1999 15:23:25
If you are refering to the pully on the shaft. I used an allen wrench that was small enough to fit in the key-way and tapped it out that way. It took some work tapping the pully in and out to work the key loose but I finally got it out far enough to get a pair of chanal locks on the key and worked it loose. I also used a rust eater to soak it loose. You can find replacement parts at www3.sears.com You will want to replace the gasket around the body and cover the gears and chain with a heavy grease. Be sure to check the bearings as they may be bad. Also there may be wear to the drive gear and shaft. Hope this helps.
Bill
