Early 70's Ford LGT 125, 145, 165
Terry
12-01-1999 07:43:21
Looking for some old 125, 145, or 165 jacobson fords to buy whole or parts. Must be the type with the oil pan welded into the frame. can anyone help.
jon_in_MD
06-25-2002 14:01:07
 Re: high performance Briggs in reply to bwood52, 06-25-2002 08:41:26
Link
Dick A
06-18-2002 10:50:51
 Wisc. in reply to bwood52, 06-25-2002 08:41:26
tyson davis
04-28-2002 11:32:01
 montgomery wards rototiller in reply to bwood52, 06-25-2002 08:41:26
Bob WOOD
04-16-2001 15:20:57
 Re: Early 70's Ford LGT 125, 145, 165 in reply to Terry, 12-01-1999 07:43:21
LOOKING FOR SHOP MANUAL PARTS MANUAL OWNERS MANUAL WIRING DIAGRAM FOR A FORD LGT 125 HYDRO-MATIC 12 HORSE POWER OR ANY RELATED MANUALS FOR THIS LAWN TRACTOR. EARLY 72 TO 76 YEARS.
mike maerz
11-18-2000 15:45:24
My tractor started last week fine, now this week I have no spark. What is the best way to troubleshoot?? I've tried new plug, checked the wiring and recharged the battery.
rick
06-08-2002 21:36:54
 Re: Kohler 12hp in reply to Ryan, 06-08-2002 20:16:08
The Cub 125 was made in 67/68. As far as the rest goes, E. all of the above. I'd check the head and head gasket. If the cooling fins are pluged or the tin is missing the head overheats and will melt on the Kohler 1 cyl engines. It's been a long time but I think that the valves are ajustable without grinding. Could be that the wronge plug was used and melted a hole in the piston.
pat
07-08-2000 11:36:43
I have one with worn engine, otherwise it burns tires, and gets wheelies. im in michigan. email me for more
Al Leininger
08-27-2002 08:57:14
 Re: Re: Early 70's Ford LGT 125, 145, 165 in reply to pat, 07-08-2000 11:36:43
I am looking for a steering wheel and a front left hand spindle for a Ford 145 (made by Jacobson) tractor. I will be willing to buy the entire front axle if necessary. Thank you.
Al Leininger
08-27-2002 08:51:33
I'm looking for a left hand front spindle for a Ford 145 (Made by Jacobson). If necessary I will take the whole front axle. Thank you.
Mark
06-26-2002 12:52:06
Looking for a steering box for an early 70's LGT 145.
WALTER
06-11-2000 17:44:03
TERRY I DON'T HAVE ANY PARTS FOR SALE. BUT I AM LOOKING FOR THE OWNERS MANUAL FOR FORD LGT 165 BUILT BY JACOBSON. IF YOU CAN HELP I WOULD APPRECIATE IT. THANKS
Monte
01-19-2001 12:48:17
 Re: Re: Early 70's Ford LGT 125, 145, 165 in reply to WALTER, 06-11-2000 17:44:03
I was wondering if you ever found a owners manual for the Ford LGT 165 I bought a LGT 165 and need to know how to hook up the snow thrower. If you know where I can get a manual please email me
rick
06-08-2002 21:39:27
 Re: Cub Cadet 149 Loss of Power Under Load in reply to Kurt Rowell, 06-07-2002 21:42:14
Try adjusting the card high speed setting. Do it with the pto engaged.
Pete in Ks
12-02-1999 07:07:50
Terry, If I'm not mistaken the only one that had the pan welded to the frame was the 145. The 125 and 165 mounted the engines to a flat plate and later they all mounted to motor mounts.
Kevin(Ohio)
12-04-1999 15:07:08
 Re: Re: Early 70's Ford LGT 125, 145, 165 in reply to Pete in Ks, 12-02-1999 07:07:50
I have a 145 that has the pan welded to the frame. E-mail me and i will send you the details.
Terry
12-06-1999 05:31:01
 Re: Re: Re: Early 70's Ford LGT 125, 145, 165 in reply to Kevin(Ohio), 12-04-1999 15:07:08
Kevin please e mail me about your LGT 145. Im located in northern KY. I have tried to e mail you but it will not go thru. THANKS
