Economy tractor ID
Stan Jordan
12-05-1998 16:39:52
I have an Economy tractor with 24"rear tires
and 12" front tires Serial # 10155 i would
like to find out what year this tractor was
built? Thanks
Greg
12-08-1998 11:38:58
 Re: Economy tractor ID in reply to Stan Jordan, 12-05-1998 16:39:52
: I have an Economy tractor with 24"rear tires
: and 12" front tires Serial # 10155 i would
: like to find out what year this tractor was
: built? Thanks
Your tractor is a 1963.
Greg
12-06-1998 08:18:07
Stan, I will run your number when I get a chance. It looks like an older model tractor. If you have the pulley showing in the front, you don't have the electric clutch - which is required for the roto-tiller. You can convert it if you like, but a new electric clutch runs around 4 bills.
Greg
12-06-1998 08:21:34
 Re: Re: Economy tractor ID in reply to Greg, 12-06-1998 08:18:07
: Stan, I will run your number when I get a chance. It looks like an older model tractor. If you have the pulley showing in the front, you don't have the electric clutch - which is required for the roto-tiller. You can convert it if you like, but a new electric clutch runs around 4 bills.
Stan, I just realized my mistake, I will still run the serial number for you. I know that you are not looking for the roto-tiller implement.
