69 jacobson 10 hp chief transmission
Hogan
12-14-1999 08:43:48
I have a 69 jacobson 10 hp chief garden tractor with a 4 speed transmission. The transmission is locked between gears need to repair or replace
ro
12-19-1999 17:47:43
 Re: 69 jacobson 10 hp chief transmission in reply to Hogan, 12-14-1999 08:43:48
Hello.
I'm not specifically familiar with your transmission, however, I'd wager that you've simply had the shift mechanism, inside, slip past whatever was designed to protect it from locking.
I've had this happen on 2 JD's, only I didn't realize what had happened until I forced the first one and broke the teeth on about $200 worth of gears.
A number of the older tractors used the same or very similar gear box/transaxle. If yours has the gear shift lever coming out of the transmission, with 3 --1/4 inch hex head bolts holding the mechanism to the transmission case, just loosen these bolts and pull off the gearshift lever. You'll quickly be able to see if the slots are aligned as they should be.
Good luck.
Bill Rokaitis
01-05-2001 12:53:01
 Re: Re: 69 jacobson 10 hp chief transmission in reply to ro, 12-19-1999 17:47:43
I know a guy near me who has a transmission. E-mail me and I'll give you the details.
